Re: How do I get to water jackets?
Have you tested the water pressure?<br /><br />Before attempting to remove the bolts spray em' down with some PB plaster. Even try a mapp torch.<br /><br />When loosening the bolts, I find it's best to go back and forth if it seems like the bolt doesn't want to come out. That is, try loosening it then tighten it. Give it some heat, spray a little more PB, back and forth...some heat...you get the idea. Breaking the bolt isn't the bad part, it's striping the internal thread that sucks and then you have heli-coil it which can also be troublesome.
