Hi everyone, I have a 1968 Johnson 100hp Outboard, at least I am told its a 68, here are the numbers<br /><br />Mod V4TL-14B<br />SER J2988985<br /><br /> I want to check the coil, I know there is a way to test the resistance using a Ohmeter, just not sure what terminals to check and what the reading should be for a coil.<br /><br />It looks like a car coil, just a little shorter, has the standard positive and negitive terms and the coil wire.<br /><br />The guy I got the boat and motor from had no spark when he got it, I had found he had a negitive wire on the positive side of the coil, motor fired then, now he says no spark again, but he had so many wires unplugged it was not funny, I am planning to reconnect and try it and go from there, so if anyone can help with the specs on a coil test, I would appreciate it.<br /><br />Thanks<br />Rick
