I'm going to see a boat tomorrow and will need to at least make sure the motor turns over after sitting for awhile, It's 305 VP. There is a pump ahead of crankshaft pulley and I didn't have a chance to deal with this setup before.
Is there something I can put a socket on behind the pump? What size? Starter won't come alive most likely from corrosion on electrical connections somewhere.
Thanks.
Ooops... posted in the wrong section... Can be moved?
Thanks.
