Re: How do I clean my galvinized trailer?
Originally posted by SoLittle:<br /> Best thing for galvanized trailers is to fresh water flush after use if you dunk in salt water and then leave them alone. Putting any kind of acid might make them look "pretty" but will strip them of the galvanized coating.
Exactly. The dull finish indicates that the galvanizing is doing its job. Removing it will just start another cycle of dulling.<br /><br />A galvanized trailer is not meant to be "pretty", it's meant to stand up to dunking in salt water. Anyone who wants a "pretty" salt water trailer should consider aluminum. Even that will discolor but it can be polished back to a decent shine. Personally, I'd rather be boating than polishing the trailer.
<br /><br />I rinse mine after each use (and flush the brakes) and clean it with a pressure washer from time to time.<br /><br />
Is it worth removing all the moving parts and getting it sandblasted and dip galvanised?
No, the inside of the tubes cannot be sandblasted. It's just as likely that it will rust from the inside. If there's no drainage holes then it's more likely.
