How do I change the water pump impeller
OhNoMrBill1960
I have a 650 Mercury 1964 65HP and want to change the water pump impeller. Do I drop the lower unit and seperate the pump and change the impeller just like that or is there more to it? Also how much is a new impeller. I know I know cheaper than a new motor but could someone give me an idea. Thanks
JB
Re: How do I change the water pump impeller
Hi, again, Bill.<br /><br />First, you get yourself a Repair Manual. Even old timers will not try an unfamiliar task without one.<br /><br />Bottom of the page, click on Repair Manuals.<br /><br />After you have done the job you will have it for the next time.<br /><br />Good luck. :)
CU2NITE
Bill,<br />You may want to change the houseing also. Impeller and houseing around 40 bucks. Not tough to change with a manual. Clymer has great manuals. Good luck!<br />CU
OhNoMrBill1960
Thanks JB and CU,<br />I have had a pontoon boat for a few years but it has never given me a hint of trouble and it is stored at a marina for the winter and they service it. But I bought second boat and it is a bit of a handyman special so I am starting to do a bit of work on it myself. IBoats and it's members have been really helpful. One thing I can't get over is how everyone swears by a Shop Manual. I guess I'll be picking one up. Once again thanks for the assistance.
