Re: how can i test my tach?
If an outboard motor tachometer:
To test the tachometer signal, connect an oscilloscope to it. You should see a pulsing DC waveform with a positive peak near the battery voltage, a negative peak near ground or slightly below, and a frequency that corresponds to the rotational speed of the engine multiplied by the number of pulses used in the tachometer calibration setting. For example, if a six-pulse tachometer and the engine running at 600-RPM, the frequency of the tachometer signal would be
600-Revolutions/Min x 6-pulses/1-revolution x 1-min/60-sec = 60-pulses/sec
