I have a 95hp '67 Mercury Outboard serial #2124524. This past May, I recieved the boat as a gift from my pop and connected the battery backwards, the red cable is a very dark shade of maroon. This mistake cost me close to $300 and ten times that in heart felt sorrow for hurting "pops boat" - I ended up replacing the switchbox and the rectifier and ended up learning about IBOATS in the process. I do have a manuel and am slightly mechanicaly inclined (Shop teacher). Never really got into trouble shooting charging systems so heres a couple of questions before I start to tinker. 1) How long will a 95hp Merc run on a fully charged battery before craping out? (my harley will make it about 300 miles - 4hrs.)Also, question 2)should I have replaced anything else - never though to check that the boat was charging, I had soild my shorts with the fact that it was running. 3 When checking that the charging system is working on my bike, first I did a voltage check with the engine off, then turned it on and check the voltage - on the bike, it was .03volts less and turned out to be the voltage regulator. Is this how I should go about checking the Boat??
