How Big Should Trailer Winch Be?
stb100
Hi,
Replacing an ancient broken winch. Is one I bought gonna be big enough? Old one says capacity: 2800lbs. New one says 1500lbs.
Boat is an old 20' Wellcraft 200 Elite -- 1983 w/a 260hp Merc...
Not sure about "load" and whether I need to to same size the replacement. Anyone know the deal w/ the capacity rating, etc...
THANKS!!
licketdsplit756
Re: How Big Should Trailer Winch Be?
a rule of thumb i use personaly. double your boat weight. my bass boat is 1300 pounds i use a 2500 wench.i figure with gear and all. gas all that adds a few ponds.not to metion the fact. your on a incline at the ramp..more is better then a disapointing moment.
stb100
Thanks for your reply...Probably oughta upgrade it.
Bridgeport, IL...that near Sumner?
tashasdaddy
i have stripped a couple of winches, in bad loading situations. luckily i had a come-a-long in the truck.
Rancherlee
depends on the trailer type also. I've got a 2500# on my trailer for my 1300# boat and it won't budge the boat on the Bunks out of the water without stripping the handle out. A 1500# winch for your 20' boat is way too small.
no1shep
1500 lbs. sounds small,but if you are loading your boat correctly ,you should only be pulling the boat a short distance(and only a portion of the weight of the boat).the boat should nearly float onto the trailer.i have a 3500 lb. boat and a 2500lb.winch.
lovedssron5
I own a tow truck and have found the I can double my pulling capacity with a snatch block (pully)
burroak
You can quadruple it if you add anotherpulley, but you better bring a lunch.:D
A heavy duty winch is only needed when you are making a dead pull of all the boat. Sinking the trailer more will permit you to pull it on hand over hand; driving it onto the trailer eliminates any question of winch rating. Alcohol should not be involved when attempting this, however.
