30 hp Johnson has sat up for a while, but cranks up with a couple of pulls. Not pumping water though. With help from jasper and others I have gotten the LU apart and looked at everything and looks ok. Impeller looks new, pump housing seems fine. If I can hook water to the copper water intake pipe that runs to the block, could it determine if the route is clogged? Will it pee with forced water or does the motor have to be running to expel water?
