kkuhia
- Jul 15, 2006
- 49
Alright, I finally got my parts (exhaust manifold and tilt unit) and installed them. I changed all the fluids in the boat (including the gas). I was running the engine on muffs after an oil change (to get any water out of the oil) and it ran very smooth for about 10 minutes. I was just about to turn off the engine (to change the oil again) when it died. The timing belt had come off! It didn't look like it broke. What would cause it to come off? Is it very difficult to fix? There does appear to be a little rust on a couple of the pulleys that the timing belt goes around.
Also, and I think this is the worst of the two, I was looking inside the valve cover to see if there was any forthy oil and I noticed what looked like a few little rust spots on a couple of the cam shaft lobes. How bad is that and what does that say about the rest of the engine? Am I just wasting my time on this thing?
There is some rust on some of the outside of the engine (on some of the gears and pulleys on the front of the engine). Compression check looked pretty good (160, 165, 165, 170), but it seems like if there is rust on the cam shaft lobes, wouldn't there be rust throughout the engine (block, etc)? I'm not quite sure what to do next.
