headdamage
- Sep 11, 2011
- 11
I just had a look at a 35hp 1980 Johnson short shaft tiller motor today. Listed as in great shape all good to go. I brought my engine stand and muffs to check it out. Started and ran great, put it in forward not problem, tried to put in reverse and no good, no mater what I and the owner tried it would not go into reverse. Had a look at the prop and the shaft can wiggle around a bit and the prop has almost half a rotation of slack in it when in forward gear. Checked the lower oil and it smelled bad, was dark and full of sparkles, after wiping the oil off of my fingers they where covered in little silver flakes of metal. Any chance that this lower is repairable or is it likely a complete write off?
