How accurate are ALL depthfinders?
waterinthefuel
I was reading all of the thread titles, and nobody challenges the accuracy of the depth readings given by these little contraptions. If you don't have a tapemeasure to stick over the side, what's to say the depth your seeing isn't 5, 6, or even 8 feet off? I am not talking about the few inches off because the transducer is under or on the bottom of the boat. I simply mean, are they all "bang on" accurate at measuring depth?<br /><br />I'm totally disregarding accuracy of drawing the bottom and bottom structure/hardness.
Boatist
Re: How accurate are ALL depthfinders?
Unless your checking for hull and outdrive clearance do you really care. No unit is going to be perfect but they are very good. Water temperature and density of the water affect the speed of sound and so that will affect the reading slightly. Still unless making sure have outdrive clearance or making a NOAA chart who cares?
waterinthefuel
Well, if I'm going to spend hundreds or thousands on a unit, if its not bang on accurate, whats the point? <br /><br />As well, there have been times where the fish are holding in 12 feet of water, where 11 or 13 was totally dead. (on flats)<br /><br />I was only wondering anyway. How does the NOAA get their depths? I have a feeling it isn't with a tape measure.
Boatist
Next unit weather GPS or Fishfinder will likely cost over $1000. You do not get more accuracy. What you get is color, bigger screen, higher resolution, more power for deeper water, dual frequency for deeper water and a wide and narrow cone angle, more sensitive reciever. I do not own a color unit but my next unit will be color. I have had the chance to see the Lowrance LCX 16 on a boat I was fishing on. This was a 26 foot party boat. My depth finder gives me all the same infomation as this unit but there is a big difference. With the bigger color unit when we pulled into a new spot from the back of the boat I could see the depth, what type bottom we had and our drift speed. With that info could put on the right weight the first time. Drift fishing again from the back of the boat I could look up and see the reef we were over before the lines got to it and adjust my fishing method. Also while bottom fishing could look up and see a school of fish 20 feet off the bottom. I am probably a fool but next unit I buy will be a bigger color unit just because so much easier to read away from the helm station. I do not have buckets of money but I do think it is worth extra money.
Ralph 123
These things get independently reviewed and tested all the time by boating mags. The technology has been around a long time and is well understood and proven. Here is a recent review of some models:<br /><br /> Depth finder reviews <br /><br />I can tell you from personal experience with Garmrin and HB, they are very accurate. I have both installed in my boat. The HB is an HR600 in dash depth only and the Garmin is a 160 fishfinder. They both show the same depth when I check their accuracy. My only problem with the HB, is I sometimes lose the depth at speed.
walleyehed
Most all units have a "buffer" built into the unit to read about 2 ft shallower than actual, and mounting position affects this as well, but when transom mounted, you have no control over the draft of your hull, so in 36" of water, it may be flashing zero, but "most" are fairly consistant to that point.
AndyL
There are so many errors that can creep in when using an ordinary echosounder from a small boat that the depth indicated is really just a best average. If you consider the angle the transducer sits may not be absolutely perpendicular to the sea floor than you instantly have a "hypotenuse" error, couple that with the added effect of the boat rolling or pitching and changes in salinity affecting the speed of sound through the different depths,and the cone angle of the unit, its a wonder it works at all. That said I have found that the error is rarely more than a few feet in a hundred or so as I use mine primarily to check out diving sites, The depth usually agrees with my depth guage when I reach the bottom.
18rabbit
The way technology R&D works, papers get published and patents get filed. Competitors read the papers and figure out a way to get around the patents. Both GPS and sounding are solid technologies. Any manufacture’s product can do these well. Construction aside, the differences will be in how the received signal is processed and displayed.<br /><br />NOAA and the US Navy’s Hydrographic Survey Unit use towed sonar for mapping. The HSL’s navigate with an Airmar Odem transducer…slightly smaller than a box of Coronas, 24-bottles . Pocket mounted because every HSL gets grounded on the rocks. You would think someone could just hop out and measure the water’s depth with a bamboo stick?!? :) <br /><br />About 10-years ago a retired capt’n of nuke subs explained how satellites were used to map the ocean’s floor to within ¼-in for use in sub navigating. Didn’t say if they actually use that accuracy.<br /><br />Boatist – Simrad, w/10-in SunView display. It has no competition.
ThomWV
There is no buffer built in to degrade the depth in any machine made. All of them are as accurate as their internal clocks, that is the limiting factor, and those things are so accurate that there is absolutly no discernable difference between any of them as far as absolute accuracy goes.<br /><br />As far as a keel offset, almost any fish finder worth mentioning has that feature and it is always user-adjustable with the factory preset at zero.<br /><br />You can spend a lot more than a grand on one, even for recreational use. I'm using a Furuno 582L with an Airmar M260 transducer so I'm pretty familiar with how much you can spend on one.<br /><br />As much as that pretty little booger costs its not one bit more accurate on bottom depth than Humminbird's least expensive model. It might shoot a lot deeper (upwards of 3,000 foot maximum depth in saltwater) and its discrimination is something that can't begin to be approached by anything else on the market (with the possible exception of those new digital units by Ray Marine) but its not once single foot more accurate than that Humminbird.<br /><br />In terms of absolute accuracy I have no doubt that the are all within one foot, and some much better than that.<br /><br />Thom
walleyehed
ThomWV, don't know where yer coming from on this, but it's standard practice for a 2ft buffer.....call the manufacturer.<br />The speed of the return is so fast at shallow depths, that if calibrated to zero, it would show negative in 2 to 3 ft water...
roscoe
I don't know what the manufacturers policy is, but my cheap little Cuda unit shows 1' when I am in 1' of water. <br /><br />The shallow alarm goes off at 2' when set at 2'. <br /><br />It doesn't go of at 4' when set at 2'.
jam39vw995
I checked the accuracy of mine with my downrigger.<br /><br />Noted depth on my Eagle Fish Easy and dropped a cannon ball to the bottom.<br /><br />It was +/- a foot.
ThomWV
Walleyehed,<br /><br />There are only two things that keep a fish finder from reading in water of less than two feet and they are related in a sense.<br /><br />The first thing that prevents them from reading shallow is simply a timeing problem. Transducers are required to do two utterly opposite things and to alternate which one they are doing. The two things are; first, to convert an electrical signal from the display unit into sound. Second; the convert sound energy into electrical energy to send back to the display unit for processing. No transducer can do both things at once. <br /><br />With that in mind you have to consider two properties of the signal sent to the transducer by the display unit. The first property is the pulse repetition rate, which is simply the number of times if fires in a period of time. The second property is the pulse length, which is to say for how long is the signal being sent. Both of these parameters vary by the depth range the finder is set to. The deeper the maximum depth in the range the slower the pulse repetition rate and the shorter the pulse duration.<br /><br />Just like any person no transducer can talk and hear at the same time and every time they talk that ping they make has a life span, then there is a blank period in which the transducer waits for a return echo, and then at some time governed by the pulse repetition rate it will fire again. The point is that with the speed of sound in water constant at 4,500 feet per second the very beginning of an outgoing sound wave travels some distance while the sound is still being made, and because we're talking about an echo here it means that whatever that time is divided into 4,500 will give you how far and dividing that number by 2 will give you the minimum depth the fish finder is capable of measuring. Its really that simple. It can't hear the return echo because its comming back to the transducer while the transducer is still making a noise. <br /><br />To understand the second problem, which is similar to the first, you have to understand that the sound that is made by a trasducer is not very clean. By that I mean that it does not have a distinct beginnning and end. What actually happens (and remember this is very minute) is that when the pulse of electricity from the display unit hits the piezeolecectric element in the transducer it not only makes a distinct ping (its actually more of a click) at the same time the transducer will continue to ring just a little bit, like a bell would. Unfortunately for a transducer that ringing sound (which is measured by a value which is normally labeled "Q") is not different from anyother sound - and it can't hear when its talking, or in this case ringing. It is that ringing that blocks out the top part of the screen, usually just a couple of inches. On the other end of the stick all return echos also produce a bit of ringing following the true echo. It is this return echo that causes a bit of fuzziness in the display of small hard targets. For whatever its worth the Q value for most standard transducers is in the high 20's to the low 30's. If you really want extremely clear pictures in shallow water it is imperative that you use a transducer with a low Q value. For whatever its worth the transducer I use has Q values of 8 at 50 kHz and 10 at 200 kHz. There are other features about it that contribute to this besides the size of the transducer element but overall it has about 50 times the sensitivity (17 dB) of the standard transducer. Even at that it still won't shoot shallow targets all that well, simply because my maximum pulse repetition rate is 1,500 pulses per minute with a minimum pulse duration of 0.13 ms. It you take those numbers and do the math you see that the absolute minimum depth I could possibly shoot at would be half of a little less than three and a half feet, and then you have to add the outgoing and incomming ring to it (that pesky old Q factor).<br /><br />So, that's generally what stops you from shooting shallow, not a buffer.<br /><br />Now there is another feature that almost all decent fish finders have that is called the keel offset. What it allows you to do is add or add to the indicated depth to make up for the placement of the transducer relative to the water surface. Some guys like to set theirs so that what is indicated is the depth below their running gear, most folks never touch it at all. About the only time that haveing been reset will ever get you into trouble is if you dont' know about it having been done and are in an inboard boat. But even at that the depth limitation below the transducer will be limited to the things I mentioned above. The display unit, and all of its intricate software, will still read down to zero if a suitable signal can be processed to give that result.<br /><br />By the way, I do understand how transducer's work, at least to the extent that a nonprofessional interested amateur can.<br /><br />Thom
walleyehed
Well......I guess I had that one coming :rolleyes: <br />I've got 3 boats with a total of 5 FF, and not one of them (2 Garmin, 2 Lowrance, and 1 Eagle) has ever shown me any different than 2ft deeper than their (transducer)location. <br />Some, yes you can program what you want for a "zero", others you can't such as the older Lowrance still in my Dad's boat, and I'll be darned.....in 5ft actual depth, it's showing 2.<br />I've only been doing this for about 28yrs, but I'll take your word for it, but I've still never seen a fixed unit show actual depth...ever....I've got many friends with boats, and I ain't seen one yet that shows actual, but I'll take your word for it, as I said.
ThomWV
Kenny,<br /><br />I know what you mean.
<br /><br />In the real world I pay a lot of attention to my fish finder in shallow water for navigation purposes, not for fishing, and I don't trust a thing it says in less than about 6 feet. I do, however, flip it down to the smallest range - which I have set to 15 feet - and simply watch the bottom on the screen, with the gain set at maximum, when I have that need. Maybe I should explain.<br /><br />We fish from the same place about 90% of the time. Its a public facility in North Carolina (I live in West Virginia) called the Oregon Inlet Fishing Center. When you go out from there you can follow a mainatined channel for about 4 miles to get to the Inlet and access to the ocean or you can follow a privately marked natural channel and cut that distance about in half. The way you go is obvious, the private channel, but it has its perils as well. Its narrow and shallow. Fortunately it does not have abrupt banks, so to speak, and so you can see if you're getting to close to the sides by keeping a close eye on the fish finder when you're running. I don't have any keel-offset cranked into my fish finder and the boat draws about 2 feet of water so if it were to read 2 or three feet of water I start getting real nervious. I watch the picture and pay very little attention to the numbers when we are steaming alone up that channel but if its low tide <br /><br />I am sweating bullits every inch of the way.
<br /><br />By the way, and this really seems to suprise a lot of folks at first, the big boats (boats in the 45~60 foot range are common in this little channel) are great to follow through this channel, but don't get in their way if they are behind you.<br /><br />It would appear that you and I have been doing this sort of thing for about the same time. I started in the Chesapeake in the 50's as a kid, and then we went to Florida. I fished the keys in the late 50's and though the 60's and went back there in the 70's after I got out of the Army. We moved up here in the mid 80's and started making the trek to North Carolina to fish off shore in the mid 80's. I'm starting to get a little old for it now, the muscles and joints aren't what they used to be for those long long days off shore, but then you have to ask yourself ... how's a guy gonna quit?<br /><br />About all I know to do is to try and stay in shape
and hope to be able to do this for another few years.<br /><br />Thom
walleyehed
Ditto on the "shape" thing......my dimensions are getting closer to "square" every day :D :D
waterinthefuel
I know that my new (got it Thursday) Garmin 240 Blue has the ability to compensate for "keel offset" for how deep the transducer is in the water. It works great but has a very aggravating quality that is discussed in another thread.<br /><br />I also for a fact know I've had my old Lowrance say it was 3 feet deep and my 6.6 foot fishing pole couldn't reach the bottom.
waterinthefuel
ThomWV, does this "2 foot buffer" exist? This fellah seems to be pretty confident that there is one.
ThomWV
What I figured out was that Walleyehead and I were talking about the same thing but using different terms.<br /><br />What he is calling a buffer I would probably call something like an acoustic shadow. To me a buffer would be an area of the view that the fish finder maker had purposfully blanked out, and that could be anywhere of course and it would be done with the display unit's software. No maker of bottom boxes does that but at the same time Kenny was right about the top couple of feet being blocked out, its just that it wasn't done on purpose. An explaination is due.<br /><br />OK, lets break out the old calculator for a moment here (not really, this is simply arithmatic). Three things have to be known to understand why we can't read shallow, or the very top of deep water. The first thing is that the speed of sound in water is constant at about 4,500 feet per second. The second thing is that every outgoing ping lasts for some period of time. The third thing is that the transducer has two functions, to send out sound signals and to receive sound signals, and that it can not do both at once. I think you see where I'm going already.<br /><br />The minimum pulse duration for most recreational fish finders is somewhere in the area of a half a millisecond. On top of that there is a bit of ringing of the transducer which artificially extends the actually outgoing ping (which as you already know sounds like a click) so that the actual outgoing sound lasts about 0.75 ms. A millisecond is one onethousands of a second and if sound travels through water at 4,500 feet per second that means that it travles through about 4.5 feet of water in one millisecond. What we're talking about here is a sound that lasts for three quarters of a millisecond so we simply multiply 0.75 (three quarters of a millisecond) times 4.5 (how far sound travels in one millisecond). That gives us roughly three and a half feet. So, remembering that the transducer can't hear a return echo while its making an outgoing sound what we see is that with the shortest click the fish finder can make the sound wave will travel about three and a half feet before it's echo can be heard. The sound has to travel down and then back so we can divide that three and a half feet by 2 to see the minimum depth the fish finder can read. It comes out to just under two feet. So that's it. From the beginning of a ping when the very beginning of the sound wave leaves the transducer until the earliest time its return echo could possibly be heard the sound would travle just a bit less than 4 feet, but its a 2-way trip, down and back, so the actual depth is half of that distance. Make sense?<br /><br />And that's what I meant when I said we were disagreeing about something we agreed on. Kenny said that the fish finder couldn't see in the first two feet because of a buffer and I say that it can't see inside the first couple of feet because of physical limitations of the equipment. In the end you can't see in the first couple of feet no matter which of us is right.<br /><br />So, is it making any sense now?
<br /><br />Thom
lepper
I use mine for really only a couple of scanarios.. going up an unknown river... so I can see the depth.. and by gum.. when my says it is less then a 1foot. my kicker starts jumping out of the water on me!!<br /><br />and when i'm out fishing in the ocean to find all them tasty bottom fish out there..<br />d
