Hey you mechanic types, I had an hour meter installed on my boat but it was wired to the on position on my key switch. Every time I forget the key on I add time to my meter that the motor is not running. The last time I accidently added 200 hours. <br /><br />Now I have a new hour meter comming that I will put the correct time back on, but I need a better way to wire it. <br /><br />My question is this. Can I tap into the tach wire from the motor for a power source for the meter without screwing up my tachometer readings? If not, are there any other suggestions for a motor on hot wire? <br /><br />BTW, its a 2002 honda 4stroke 50hp motor. <br /><br />Thanks, <br />jgun
