I have a 1996 Johnson Fast Strike 150 and I have disconnected my VRO. Saturday I was running and my overheat warning went off. I checked the water pressure (24 pounds) and the water coming out the pee-hole - it was fine. When I throttled back, the horn stopped. It ran fine for about 25 seconds and then shut itself off. I restarted it...it shut itself off. The engine was NOT hot. After trolling about 10 minutes and periodically cranking, I had an inspiration....check the fuel bulb. It was flat...I was out of gas in one tank. When I switched over it cranked right up but seemed like I had a fouled plug. The horn did not sound again.<br /><br />I came to work this morning and forgot to see what plug I need to get for replacements. Is it QL78YC (champion)? Since I'm mixing my oil, should I get a hotter running plug? Thanks!<br /><br />Bob
