Re: hoting up 68 18 hp evinrude
A very interesting thing about those motors -- the blocks were almost the same. The 25 crank was "balanced" and the wrist pin is actually lower in the 18 and 20 piston so the piston comes up higher. You'd think the 25 would be the one with the lower hole. Anyway, the heads are different too. <br /><br />When we raced in that class, 25SS, thats what we used. A 25 block, crank and head with an 18 piston. It worked great on a raceboat but we tried it a couple of times on a small aluminum Starcraft but burned a piston both times. We also used a carb off of a 50 or 70. <br /><br />But youre back to the same old scenario -- if you arent twisting the 18 now pretty high, you may not see any difference. Especially if your boat doesnt respond to small torque increases.<br /><br />If you were inclined to try something, I'd just get a 25 head and try that. Your compression will be higher so you will have to run the good fuel. Just try it and keep a close eye on the pistons. I'd jet it up to the point it "blubbers" and then back down.<br /><br />Good luck!
