Hot water tank rust
JC1933
Hi...all i have a tank that is rusting at the two outlet pipe conections,could this be caused by my water softner?I have identical tank that is not on softened water that is in perfect condition.Both are of the same make and age.Would someone know the reason for this? thanks in advance. J.C. :confused:
BoatBuoy
Re: Hot water tank rust
There may be 2 reasons for this. First, most water utilities add calcium compounds, both to flocculate during the purification process and to coat their pipes on the inside to prevent rust. The water softener replaces the calcium with sodium from the brine tank. Second, the sodium is more soluble than the calcium, but is also more corrosive when ionized with the chlorine.
fixin
Are you talking about on the outside of the tank?<br />If so,it more than likely is do to condensation/humidity in the room of the tank.<br />I have had a water softener(well water)for 10 years,and still have the same water heater.
rwise
salt increases rust, when I bought the house I am in now there WAS a water softener installed. main tank had just been replaced, and I replaced the other about 4 years ago. also relace all galvanized fittings as they were rusted inside to the point of water just barly flowing through them. good luck, just my thoughts.<br />Richard
JC1933
BoatBuoy..Fixen.and Richard..Thanks guys for your input.I took the two top connectors apart and found that they wer rusted through the gasket,cleaned these up with new gaskets,looks ok for now...you all have a happy new year :rolleyes: ;)
