Re: Hot Dog Bass
I tried the salty craw and then used Yum crawfish scent and no luck on either. So I figured what the heck I gave the craw a shot of the Kicki'n Bass garlic- still nothing. I looked at the craw and saw where it is hollow and has an opening from under the front so I cut some hotdog and stuffed the salty craw and finally got two hits in about an hour but missed hooking the bass. I got tired of working at it and went to a hook with hotdog on it and caught and released 20 bass and 2 bluegills in about 2 hours. The only thing that I have seen that works consistently here is the hotdogs except for one guy who was catching fish on bread and a double hook.
Now put that bass tackle away and get some ultra lite tackle. 4# test fluorocarbon line, a 1000 size reel, and a 5 or 6' UL rod with a little backbone. Get some small lures like little crappie jigs, or as I prefer 1/16 or 1/8 oz. Roostertail inline spinners in white, yellow, and green.
Take your bottle of crafish scent with you and put 1 drop on the roostertail feather, cast the roostertail out and let it sink to the bottom. Start counting by 100's as soon as it hits the water, 101 102 103 104. If the lure hits bottom at 105 that area of the pond is about 5' deep. Give the roostertail a pull with the rod and a couple quick turns of the reel handle to get the blade spinning, then slow down your retrieve so you're reeling just fast enough to keep the blade spinning. If you bring back slime or weeds on the hook start reeling on the count of 104 on the next cast.
Those bass in that lake have seen every bass lure known to man, several times and they know exactly what they are. You have to give them something they've never seen before, and they've probably never seen a roostertail worked properly. You'll catch everything in that lake if you work the lure right, but mainly bass and bluegill.
This is all I use when fishing freshwater in Fla. and people are amazed at the fish I catch. the roostertail mimicks a crippled minnow perfectly when retrieved at the right speed, just fast enough to keep the blade turning. You'll be able to feel the vibrations of the spinning blade in the rod.
Try it.
