Was going to check for spark (3000 rpm max under load, good compression) on 1985 60 hp merc and after cranking about noticed battery terminal and wires at battery very hot, burnt myself.connection at starter relay not hot.any ideas? thanks
Yep..clean all terminals..Heat is generated when an electrical current flows through resistance.
