Re: Horsepower ratings
I don't know for sure about that make of motors, but the HP difference on most of the motors that are the same size is the results of different RPM's of the engines. They accomplish this by a varity of means. <br /><br />To reduce the HP they reduce the RPM by such tricks as: A smaller carberator, A restricter plate behind the carberator, On older engines the exhaust may have been restricted, a stop in the linkage that keeps it from opening all the way, smaller reeds, a reed stop (so they can't open as far), etc.<br /><br />Changing jets on the carb will not give you the higher HP engine, but changing the carb and reeds usually will, especially on later model engines. On the later model engines, due to fuel economey and emmisions they don't restrict the exhaust system to reduce the HP.
