Horn/Bilge
Italia
2005 Four Winns Horizon 200. Horn won't work. How can I check if it's just the switch, or if the horn needs to be replaced? Also, bilge switch light stays on when boat is off. Don't remember this happening before. Not sure what triggered it. Any suggestions on both issues? Thanks.
bustermin
Banned
Re: Horn/Bilge
You dont specify if the horn is electric or pneumatic. i will assume since you placed this thread under "Electrics" that the horn is electric. first thing i would do is make sure the horn has a good ground, then take a meter or test light and check to see if you are getting power to the horn, if you are and you have good ground, the horn is bad. if you are not getting power to the horn follow the wire back to the switch and find where the power stops. if you get all the way back to the switch then the switch is bad. as for the bilge switch, it sounds like the switch is shorting.
Italia
Re: Horn/Bilge
Thanks for the advice. I'll check it out. Grazie.
