rustyscrew
- Mar 29, 2006
- 141
I am trying to get a tach from my old mercury engine to work on the newly installed evinrude 120hp (1988-v4). I believe it should work. Problem is the previous owner played with the wires a bit, so it is hard to know if things are hooked up properly.
I read 24 volts AC across the A and B ports on the binnacle when the engine is idling. Does this sound right?
When I hook it to the tach, it doesn't work... I could be just hooking it up wrong though.
thoughts?
thanks
thoughts?
thanks
