hooking up cd player, where to hook up yellow wire???
andy h
I just put a cd player in the boat yesterday, All went ok but the the clock stays on when I shut off the power. (did not do this in my jeep) I ran black to - and connected red and yellow to + It works fine but I am concerned it will kill my battery with the clock staying on. I would like to hook it up so presets will stay (like in a car) but have clock go off when key is off but I am not sure how this would work? Does it go the the ignition? can anyone shoot me in the right direction?
jimchere
Re: hooking up cd player, where to hook up yellow wire???
The standard designation for these days is the red wire hooks up to a "switched hot" meaning it only has power when the ignition is on. This red wire is power for the actual cd player and intenal amp itself. The yellow wire is intended to be a "constant hot" meaning it is hooked up to a + 12vdc source that is always on regardless of ignition switch position. The yellow wire powers the clock and maintains internal voltage in the unit to keep the presets in memory. The unit will operate with only the red wire and ground (black) hooked up, but everytime you turn off the unit it will lose the clock setting and presets. You can even hook up both red and yellow to a constant hot but this would allow you to leave the CD player turned on anytime and drain the battery (not a problem if you remember to turn off the player when not in use...but just another thing to forget and cause trouble). The yellow wire, itself hooked up to a constant source, pulls very little current (milliamps) and will take a very long time to drain a significant amount from the battery (days, if not weeks). If you operate your boat frequently I would not worry about the yellow wire draining the battery. If you are laying up the boat for a significant amount of time you probably disconnect your battery anyhow, in which case you will have to reset the clock and presets when you hook everything back up to go boating again.
andy h
Cool thanks for the help, for some reason I thought red was constant and yellow was swithched. That was my problem. In this case I am going to run yellow directly to + and run the red to my accesory switch. this way I can either shut off the stereo at the head unit or the swith. Thanks again for the help. :D
