Re: honda running problem when warmed up
DON'T KNOW IF THIS IS YOUR PROBLEM, BUT I HAVE A 7.5 HONDA, PROBABLY A 1978. IT RAN FINE WITH THE HOOD OFF BUT WOULD LOOSE RPM AND POWER WITH IT ON. THE PROBLEM TURNED OUT TO BE THE EXHAUST PIPE FROM THE BOTTOM OF HEAD TO THE LOWER UNIT HOUSING. THE EXHAUST PIPE CORRODES AWAY LEAKING EXHAUST GASSES INTO THE HOOD, STARVING THE ENGINE FOR AIR. WITH THE ENGINE RUNNING, LOOK BELOW THE CYLINDER HEAD INTO THE LOWER UNIT HOUSING FOR SIGNS OF WATER SPRAY AND EXHAUST GASSES. IF YOU SEE EITHER, THAT'S LIKELY YOUR PROBLEM.
