Honda hides the year?
dmurray
I can not figure out why Honda hides the year? It's as if it is top secret. I have a Honda BF40 Product# BAYL-1002690 Can someone tell me a site to figure the year?<br />Thanks again I-Boats
zzzzz
Re: Honda hides the year?
I don't know of a site but yours is a 1995 :cool:
outboardguy
The reason I was told that most motors don't have a year designation is that sometimes boat builders buy a bulk of engines and don't use all of them in a given production year.Without year designations on the engines the manufacturer can still install the new "year old" engines and not have a dilemma with the customer.
Navigator
dmurray,<br />Honda uses a Code after the hp rating in the model number to designate the year. <br /><br />Example <br />Model BF40AYLRTA <br /> BF = Honda Mfg<br /> 40 = horsepower<br /> AY = model year 2000<br /> L = 20 inch shaft<br /> R = remote steering<br /> T = Power Trim and Tilt<br /> A = American Market<br /><br />Here is a breakdown of the other codes<br /><br />Model Years: <br /> AX = 1999<br /> AY = 2000<br /> A1 = 2001<br /> A2 = 2002<br /> A3 = 2003<br /> A4 = 2004<br /> A5 = 2005<br /><br />Shaft Lengths<br /> S = Short 15"<br /> L = Long 20"<br /> X = Extra Long 25"<br /> XX = Extra Extra Long 30"<br /> C following = Counter Rotation<br /><br />Steering System<br /> R = Remote Control<br /> H = Tiller Handle<br /><br />Tilt & Trim<br /> T = Tilt & Trim<br /> Blank = Manual Tilt<br /> J = Jet<br /><br />These only apply to the 25hp and larger engines<br />If you want the code breakdown on the 2-20hp, let me know.<br /><br />Hope this helps...<br />Nav :cool:
dmurray
Thanks for the post... I appreciate the response and the break down. I am sure that this break down will help many in the future. This motor runs great for 10 years old.
Curlew
Nav, The Honda model number breakdown is great info. Yes, I would like to see the code breakdown for 2-20hp engines. I just bought an 8hp Honda 4 cycle, ID # BACS 1001023, and can't find anything about it. <br />Thanks in advance!
Navigator
For the lower HP Models<br /><br />Example<br />Model BFP8D3LHSA<br /><br />BF = Honda Mfg<br />P = Power Thrust Feature<br />8 = horsepower<br />D3 = model year 2003<br />L = 20 inch shaft<br />H = Throttle Grip steering<br />S = Electric Start<br />A = American Market<br /><br />Here is a breakdown of the other codes<br /><br />Model Years:<br />DX = 1999<br />DY = 2000<br />D1 = 2001<br />D2 = 2002<br />D3 = 2003<br />D4 = 2004<br />D5 = 2005<br /><br />Special Prop<br />P = Power Thrust Prop<br />Blank = Regular Prop<br /><br />Shaft Lengths<br />S = Short 15"<br />L = Long 20"<br />XL = Extra Long 25"<br /><br />Steering System<br />H = Throttle Grip<br />C = Centrifugal Clutch<br /><br />Starter options<br />S = Electric Start<br />Blank = Pull Start<br />T = Power Tilt & Electric Start<br /><br /><br />Nav :cool:
Curlew
Thanks Nav, that's good info. It doesn't help me at this time as mine seems to be older and has a different number format.<br />ZZZZZ, I tried using http://www.boats.net/parts.html <br />but got no return when I entered my hull number. Thank you both!
K7STW
Mine is also too old to come up on the parts list. BF75100032S. It is supposed to be mid eighties but???
ars02
Thanks for the information but I could use some hlep deciphering year of Mfg on my Honda 50hp 4 stroke (BAZL-1008823). This was purchased in '00 with understanding that it was a '99. I've been told it was made in '95?
zzzzz
K7- yours is a 1978.... MinneAl- yours IS a 1995 :cool:
sailor_turned_stinkpotter
zzzzzz could you post the codes for the older motors at least for the b100 so we can figure out our years ? MIne is B100L1405053<br />thanks,<br />dave.
zzzzz
my book of codes is about 20 pages long and I dont have an easy way to put them on here but yours is a 1982 :cool:
