Honda Gauge set BF50
porthole2
I just installed a Honda 50 including the Honda gauge & harness package. The tach only read up to 2000 rpm and then dropped to zero. The hour meter (in the tach) only came on after revving over 1000 rpm. After a while the tach stopped working completely.<br /><br />Also after buying and installing the water pressure gauge I found out there is no place to hook it up? Any ideas for that? Teeing into the “pee” line does not work.<br /><br />Also, the engine buzzer does not buzz when turning the key on, is it suppose to?<br />Thanks in advance
