Just purchased a used one of these and the 14 wire control box as well. I want to make sure all electrical systems(not ignition) are working, prior to firing it up. Tilt n trim seems to work, as well as the warning buzzers. I cant seem to get the starter motor to crank. Question is, what interlocks may be causing this? oil?, in gear? what else?. just to prove starter works, is there any danger in bypassing the relay and applying 12 volts directly to starter?<br /><br />Thanks Guys,<br /><br />KSAN
