honda binnacle control cable ends needed
Hi, well I got my binnacle control from E Bay. As I suspected, it is missing the cable ends/adapters & the E clips to connect the 33C control cables to the linkages. I was hoping the ones from the side mount control would fit, but they need to have a larger diameter hole to go over the pins on the binnacle mount linkages. Drilling the holes out would leave them too thin. Anyone have any extra's that I could buy, or any ideas how to make something that will work? <br /> Thanks, Bruce
radsrh
Re: honda binnacle control cable ends needed
Bit the bullet and go to your dealer and buy them, it's not cheap but look at the cost of your motor. Do it right from the start and you won't have to do it again, if you try to rig it you risk damage to your motor and even yourself and your passengers.
