Re: Honda BF8A
If your rectifier/regulator is only putting out 12.5 VDC, then it will not fully charge your battery, however it will charge your battery from the 11.5 VDC you mention up to 12.5 VDC. Since you measure 3 amps flowing, some charging must be occurring, as you recognize. Do use an accurate voltmeter, and if you do not see about 13.8 VDC, then you should consider checking to verify that your rectifier/regulator is operating correctly. The easiest way to do this is with an oscilloscope, but not everyone has one of those. In view of the 3 amps you've measured, I think you'll find with an accurate meter that you're OK. Good luck.
