honda bf8 classic
C-RAVEN
i bought a 1993 honda bf8 last year and it has been a great little trolling motor. i noticed rough idle as the weather has cooled off and i think it might be the thermostat is stuck open.<br />i use it in salt water, and there appears to be a lot of salt build up around the outside of the housing...<br />is it an easy enough task to replace the thermostat?<br />there appears to be about 10 bolts to remove.<br />i assume i should buy new gasket sets as well ?<br /><br />any advice is welcome<br /><br />thanks!
hondon
Re: honda bf8 classic
Give us a little more .Are you useing this as a kicker and running off the same fuel source as the main ?Water in your fuel?Rancid fuel?Do you get the hint?I have yet to fix an 8 with runabilaty problems because it was running too cold.
C-RAVEN
Fuel is ok, separate tank<br />i played around with it and adjusted the carb which seemed to fix it. i guess the mixture can get out of whack ??<br /><br />thanks
