Honda BF75 twin outboard, throttle cables out of sync.
pikeman59
After service the throttle cables are out of sync on My twin outboard setup. Too far away from the dealer.
Can I adjust them easily?
On the engines or at the controls?
Thanks
Pikeman59
hondam
They are adjustable on both the engine and inside the control box. With mechanical controls they are rarely if ever perfectly in line.
The control box side Honda says you screw the fitting on enough to see 2 threads coming out the opposite side of the connector. Then you do the fine tuning on the engine side.
