yorketrading
- May 30, 2005
- 1
Honda BF50 1996 , the steering main vertical shaft has probably become slightly corroded with the engine not been used for a while , it was therefore almost seized , I have freed things off a bit and greased it however it is still not good and too tight for the steering cable/wheel to operate.<br /><br />Any further tips on trying to free it further ?<br /><br />Worse scenario how complicated is it to dismantle this shaft / then clean and replace it ? <br /><br />What requires disasembling to be able to remove this shaft as I believe it is quite an envolved job ?<br /><br />Thanks
