phoenix777
- Sep 10, 2008
- 1
Hey All,
First off I am new to Hondas and relatively ignorant in some respects, but have worked on this boat some already and poured over a lot of threads. I spent more money on the boat and motor than i am willing to throw away from my own ignorance... I also bought it on an impulse as I thought it was a pretty sweet deal(3000boat, motor and trailer). Motor appeared to run great when I was buying it.. watched the guy I bought it from replace impeller the day I bought it. That being said got it home and realized it had no muffler assembly and linkage hadn't been re attached, Lets just say that the guy I bought it from also sold used cars... Realized I was dealing with a different animal than the simple tiller steer 2cycles I had before and i might be out of my element to a degree(mainly my wallet) but I can't really afford to take it to a mechanic so need learn how myself.
Motor issues
Steam is coming out of the exhaust after warm up both on muffs(taped the intake) and water out of the telltale can get pretty hot but not scalding, not steaming out of the telltale and pressure is good and consistent after initial startup. The head is hot once warmed up, not burning hot but too hot to leave my hand for long. The bottom end of upper cowling(near exhaust) is hot to the touch. I haven't had an overheat alarm go off since it has started steaming but i don't know if the alarm even works. It seamed to steam a little bit on occasion in the past but it is consistent the last few times out once warmed up and occurs at higher rpm and idle.
Also the motor loses oil at a pretty quick rate. I check it every time I go out and it seems to vary but I could easily put a quart in every 10-15 hrs.. On 2 occasions out of the many times out I have seen a small oil slick in water, but not any more than you might see on a 2cycle. When I installed the muffler I noticed a spray of oil in that area of the engine near carburetor but haven't noticed more since. Noticed on the muffs last week that there appeared to be some smoke out of the prop like a 2cycle might have been carbs from sitting a couple months but not sure. The oil loss is certainly abnormal. I'm down to learn and try and work this out myself, but I'm not sure where to even start. I'm also worried one of you is gonna say something expensive. Ive change oil and filter maybe 30 hours ago.
I am going to replace/rebuild water pump and impeller and thermostat in the next week but is there anything else obvious I could do to make sure I'm not going to burn engine up? As to the oil issue?
Thanks, I've learned a lot already from this forum.
Motor issues
