Hi, new to board. My 2000 BF 50 recently developed the following: At higher rpms the prop seems to spin, i.e. the motor revs but boat stops moving and there is a clicking noise (higher pitch than motor running). If I lower the rpms below 3000 I am able to move forward, but now the noise is appearing even at 3000 rpm and thrust is lost intermittantly, forcing me to run motor even slower. I rotated the prop by hand with motor off and in gear. In forward gear the prop turns clockwise easily with a clicking noise. It cannot be turned counter-clockwise. In reverse gear it is not possible to hand turn the prop in either direction. Since reverse seems fine, I am assuming that the clockwise rotation while in forward gear is related to the problem. Any ideas on what is wrong and how to proceed with repair?
TIA<br /><br />Jack
