Honda BF50 leaking fuel pump
AndyM1
I have a 2001 BF50--runs fine, but noticed a gas occasionally seeps from the layers of the fuel pump. It's not a lot, and it's not all the time. I wonder if simply tightening the 4 bolts & nuts will be sufficient (at least worth a try ?) , or do I need to get a rebuild kit, or just replace the pump. Any advice appreciated.
wrench 3
Tighten the bolts and see what happens. If it still leaks, pull it apart and make sure that the gaskets are the only problem before ordering a repair kit.
Sea Rider
Being a 16 year oldie, if tightening 4 bolts doesn't stop the fuel leak, internal gaskets probably are already dried, hardened, does not sit well against fuel pump's mating surfaces. If so, order a repair kit.
Happy Boating
