Honda BF50 idle and starting problems.
Fishingeric
I recently bought a older Bf50s 1980's ? The guy i bought it from put a new carb on it and said it needs to be adjusted. It is hard starting and but will start and it runs great for about 5 min or until you shut it off then it will not restart,(for awhile) Is there a way I can adjust the carb myself? Also it runs much better with the cover off, I read a post about a similiar problem someone had but never got back with the answer to the problem.it has some JB weld on the exhaust manifold I guess it could be an exhaust leak. Is that easy to replace??<br /><br /><br />Thanks in Advance<br /><br />Eric
