The high temp indicator light on my 1999 Honda BF50 remote has been lighting up shortly after the engine is started. It was first noticed when returning to dock after a 3 hour trip. The water check flow was OK and the water peeing out was definitely warmer than its source. I took the cover off and the block/head did not feel overheated (as far as I know) and the oil temp/colour/level was OK. According to the manual when a high temp occurs "the light will come on, an audible alarm will sound and the engine revs are limited to idle" in my case its only the light. Is there a way to check the temp indicator signal? Does the thermostat fail closed? What is the actual normal running temp and high temp setting? I use it on a small lake for fishing and 95% of its run time is at idle (trolling) with 5 minute bursts at 3/4 throttle to get to the next hole. Any help in this matter would be appreciated greatly.
