BF 50. Honda 5 hp possible fuel pump problems motor runs great for about two to three minutes and runs out of gas. I squeeze the bulb a couple of times and it will start right up. If I squeeze the bulb about every minute, the motor continues to run just fine, no matter what speed. I have checked the filter in the tank and the filter on the motor. I have inspected the hose to the gas tank. The fact that I can continue to squeeze the fuel bulb, and the motor continues to run just fine, leads me to believe that the fuel pump may be bad. The pump is kind of pricey and I can't find a new diaphragm by itself. Your thoughts please
