Honda BF5 oil leaking from oilpan/shaft seals & weep holes
pandora
Honda dealer states oil pans seals gone but they can't pull the shaft out it is rusted to the end where the crank fits into the shaft. You can't pull the oil pan cover over the shaft for removal...the shaft has to be pulled first am I correct and any ideas how to free.. if none, the engine is toast..fantastic enging ..dealer wants 650 to repair if the shaft can come out
isaksp00
Sometimes PB Blaster has worked better than WD40 for me - can't hurt, for 6 or 7 bucks or so.
