floridaboater1
- May 20, 2010
- 80
Hi all I just picked up a 2009 4stroke Honda bf2d 2hp outboard. I put it in some water and pulled the choke out and it started right up and idles great, but after you let it warm up for a minute and push in the choke it shuts off. If you try to rev it up with the choke out it shuts off. If you start it with the choke out and the rev it up and at the same time push in the choke it will rev up but then when you go back to idle it shuts off... I pulled the carburetor and cleaned it out. (was clean to begin with) but blew out all the passage ways and jet with 90psi put it back on and still the same thing. WHAT COULD BE THE CAUSE?????? please help.
