Honda BF225 codes?
mpsyamaha
03 bf225 Runs smooth at idle and but wont get over 4000 rpms. Recent major service, high pressure fuel pump and filter replaced with no change in symptoms.
Ive found its easy enough to jump the service connector to flash any codes the ecu has stored, but the problem is I cant find a list of what the codes are. I am getting 3 short blinks, but cant find any information online about what code 3 could indicate. The engine has over 2000 hours and has the original o2 sensor according to the owner, so i was suspecting that, but i believe that is a code 10? Any help is appreciated!
hondam
It's probably not running on all cyl. Try to isolate the cylinder or cylinders that's not running also do a leak down tester and check the timing belt.
Don't have access to the codes right now but I'll see if I can't look it up later.
