Bought new a BF20 short shaft for my 14' aluminum boat in ABOUT 2005. my boat has a 15" transom, so I knew I needed a short shaft. Simple, right? NOT! hung it on the boat, went for a test drive, and huge spray and backflow of water into the boat. After messing around AND calling the dealer to confirm short shaft via the Serial Number, I figured it must be the boat. I inserted a series of test shims until the problem was corrected, then took the boat to my aluminum guy where he added to the transom (TIG'ed a piece on to the top of the transom, did a great job). everything was fine, although the boat itself was narrow and quite a handful at speed.
I want to upgrade my boat, so knowing much more now than I did when I bought the Honda, I measured from cavitation plate to transom mount, and came up with 17 1/4". I even hung the motor on a wider Lund 14' to test (I thought maybe the weight of the motor on a lighter boat was causing the motor to sit deeper in the water), but the same backwash occured.
So the motor clearly doesn't fit a 15" transom (even though 15" - short shaft is the match), and will sit too shallow on a 20" transom, so what is my solution? I am certainly not going to buy a new boat for $3000 and modify the transom again to fit.
Thanks for any and all help in advance.
1977 21' Bayliner Admiralty
1977 14' Starcraft V5 - 60 HP Evinrude
1985 14' Naden - BF20 Honda
