The engine can start from cold crank smoothly in the morning. I turned it off for 5 minutes in the middle of lake. When I wanted to continue cruising, it can't be started for no reason. I noticed that the primer bulb can only be squeeze up to 80% hard, not fully hard as I firstly prime. We rested for around 2 hours in the middle of lake, then everything be fine again. Such intermittent starting failure happened three times in the last week. By the way, the fuel line, primer bulb, fuel filter are all newly replaced. The engine is 2003 BF15D with carburetor. Can anyone shed lights on this issue?
