Paul in Beaufort
- Mar 26, 2014
- 2
I have a 1997 Honda BF15 with a cooling issue. I recently acquired this motor and when I started it there was no water coming from the indicator port ("pee hole"). I checked the impeller and except for a tiny chip on one of the vanes it looked okay. (I've ordered a new one anyhow.) I cleaned the inlet ports on the foot and the passage seems clear into the water pump housing. I removed the thermostat cover and started the engine and there was no water flowing.
I have a couple of questions. I cannot see where the outlet hose from the pump goes. Does it go to the block or is there a hose somewhere that I cannot see that takes it elsewhere? In other words, where does the water go when it leaves the pump? Does the thermostat control flow from upstream or downstream of the water jacket? And lastly, short of taking the powerhead apart, how do you check and clear the tube from the pump up into the top?
I have poured water down the hose from the thermostat and that seems to be the outlet which exits with the exhaust through the prop so even if water were getting to that point it would keep flowing....but it's not.
Any help or information would be helpful.
Thanks,
Paul
Thanks,
Paul
