Honda BF130A 2001 High Pressure fuel pump module
moezilla
Trying to locate a fuel pump cylinder that goes in the high pressure pump casting that mounts to the vapor housing.
It shows
MH4
2F26 on the cylinder with two spade connectors
I am hoping it is available somewhere!
moezilla
honddude on iboats had this very useful info:
ou are going to need 31, 36 and 13....plus whatever other parts you determine must be replaced when you put it back together. http://www.boats.net/parts/search/Ho...TOR/parts.html
I do not know of any rebuild for these pumps.
Mike
The above is a diagram for 2004 130. Most of the 2001 130 fuel systems were updated to the one that is used in the 2004.​
