I took the boat out today and my honda would not go past 3000rpm. Once it hit 3000, it would start to stutter. Took the boat out twice before and had no problem. I made a video of it. It idles fine and shift fine. So i drove around at 3000 rpm and i decided to give it more throttle, and for 5 minutes i was able to go past 4500 rpm. Then i idle for a bit and i have the same problem. Now it wont even go past 2000 rpm. Through all this, no alarm from the remote. One green light is on. Can a failure to the high pressure fuel pump cause these kind of symptom?
https://youtu.be/HDvIjvCoW94
Towards the end while going back into the dock at 1800 rpm, i tried to give it more and i hear a small pop. Any input is appreciated. I use to work on 2 stroke engine, this is my first 4 stroke.
