Honda BF115A 2008 what prop best for boat
PhilEbarb
I have a 2008 Crest Pontoon II LE XRS that weight approx 2700lbs dry. I also have a Honda BF115A outboard that needs a new prop. I do not know my current RPMS or top speed. I would guess around 25mph. When searching for a new prop by entering serial number to engine I got approx 20 different props listed with part numbers. My question is what pitch 3 blade prop should I get to replace it with????
Ayuh,... Welcome Aboard,..... Tough question, without answers, when ya got no numbers to work with,.....
Pull the prop off the motor, 'n See what it's numbers are to start,....
steelespike
So what is a Crest II LE XRS?
Prop numbers usually appear under the prop nut.
If it's a twin toon I'm guessing an 11"pitch is a good starting point.
