Honda BF100 tighten motor?
Tacklewasher
Is there an adjustment to tighten the motor so it doesn't turn while running? Was fishing yesterday and had to babysit the motor or I'd end up going in circles.<br /><br />I need to get a manual for this thing!
scotty c
Re: Honda BF100 tighten motor?
Usually there is a steering tension adjustment on the boat somewhere.<br />Mine is a small knob located right at the bottom<br />of the steering wheel.<br />you can increase or decrease the tension on <br />the wheel, according to whether you want it <br />loose or tight.
Tacklewasher
Nope. Nope. Nope.<br /><br />This is on a 10hp tiller outboard.
dobers
i could be mistaken but i think theres a tensioner on the port side should be a bolt with a spring a little ways down the midsection assuming its an older model
