we have 2005 225hp that was losing power and stalling when bring back the throttle. when checking the problem the engine began smoking exessivly when starting (white smoke). checked the oil and the sump was full with fuel diluttion. the oil was changed a week prior. changed oil and did a commpression check as per shop man. 5 cyl were around 150 and #2 cyl was 100. man says 198-224. ran engine again and fuel was found in the sump again. is the fuel possibly from a o ring on the fuel pump? and if so can this cause the low commpression?
