bclark1974
- Jul 26, 2014
- 3
I recently bought a 15hp Honda 4 stroke. It ran well but it wasn't peeing water the way I thought it should. So I bought an impeller rebuild kit along with a thermostat. I put them both in today and it peed water better then It did previously. During high rpms it stops pissing but I shrugged that off to not enough water intake from a garden hose. When I drop it back down to idling or just above idling it starts peeing again, after a few seconds, like i would expect it to. After about 10 mins of running the engine and checking temperature of the water as it came out, it seemed ok but could be better, and then the motor shuts off. The motor doesn't feel overly hot to touch so I start again. It starts right up but then a couple seconds later it shuts off again. It does this several times till eventually i gave up on starting and started looking into a possible clog in the manifold keeping it from peeing properly. I pull the manifold off and notice lots of corrosion, one of the reasons for replacing the thermostat, so I try to clean it up a little. I decided to give up for the night and come inside and post to see if anyone has anything to add or suggestions of why the engine would cut off and if the corrosion in the manifold would possibly make it **** somewhat funny. Any input would be greatly appreciated for this is my first outboard and could possibly getting over my head fast.
