Honda B75L carburator woes
John Scholz
Hello,
I have a Honda B75L1300180 that would start and run at high speeds but would not idle. I took apart the carb and cleaned all the parts and noticed that the lower half of the emulsion tube (the long skinney brass tube with the little holes in it above the main jet) was pretty much distroyed by the former owner, there was also a ton of crud in the hole which I believe I got out.
I noticed that this little tube is shown on the exploded diagram (it is #9 in the diagram) for the carb but it is not listed as a part you can buy.
Does anyone know where I can get this tube? Also, what year is my motor?
If anyone has a used carb. or the part I will be happy to buy it?
Thanks for any help.
John Scholz
